axle problems?
axle problems?
Hi everyone,
I have a problem with a 95 neon sohc. I have a clicking sound coming from the left front that is speed dependant. Also the automatic trans is starting to leak fluid. I suspect the cv joint is bad, but could this also damage the seal that goes in the transmission?
thanks
thanks
RE: axle problems?
let me see if i can explain it better. Driving down the road under load I get a rythmic clicking, popping sound from the front left, when I let off the gas sound changes to more of a grinding noise. The clicking is totally speed dependant.
What concerns me though is that tranny is starting to leak fluid quite a bit, and Ido believethe cv joint is bad but could cause the trans seal to go out as well.
RE: axle problems?
the noise seems the same whether turning left or right, i bought an axle and trans seal and i'm going to jack it up and look at it this morning.[/align][/align]anytricks to changing the half shaft/ [/align][/align]i did a search and some people mentioned having to twist the axle to lock it in. i'm not real sure exactly what they're talking about.[/align]
Trending Topics
RE: axle problems?
well i got the car up on jackstandsand ran the tranny, the sound is definetly coming from the transmission under what looks like the cover for the differential.[/align][/align] also the cover has been braze welded and that is where the fluid has been coming out, soooooo....it looks like someone has worked on it in the past for something. i bought this car used for my daughter for college so i have a little time to get it fixed before school starts.[/align][/align]i guess my next question is what's involved in changing the differential and can it be done in the car/ [/align][/align]i'm going now to take some pics and i'lltry to get them posted.[/align][/align]thanks [/align]
