intercooler
Old Jan 8, 2007 | 12:04 AM
FastNeon84's Avatar
FastNeon84
Default intercooler
just put my intercooler up to my front and it looks like i have to cut into my front bumper support to get it to fit the way i want it to....and i dont want to do that... so does anyone know an intercooler that will fit just right under the front bumper support or any good specs for one? or should i just get an srt intercooler?
Old Jan 8, 2007 | 01:07 AM
FastNeon84's Avatar
FastNeon84
Default RE: intercooler
nevermind......found the perfect one!
Old Jan 8, 2007 | 03:47 PM
spudsterier's Avatar
spudsterier
eitherway you should have to do some cutting....i needed to cut alot for the srt intercooler to fit
[IMG]local://upfiles/29901/616E5DFF438B4ED0A759FE7731FB0925.jpg[/IMG]
Old Jan 8, 2007 | 07:20 PM
FastNeon84's Avatar
FastNeon84
damm[:@]i thought it would fit under the front bumper support without having to cut. hey are the specs for the intercooler i posted about the same as your srt4 intercooler? and what did you have to use to cut?
Old Jan 8, 2007 | 07:57 PM
spudsterier
the specsshould be about the same.....
and you will need an intercooler that has the inlet and outlet comming out the back.....if you get one that has them in the side, you wont be able to route the piping....
about 15 minuites with a sawzall and it was just how i needed it.....and you do have to cut decent sized chunk out of each side of the raiator support
Old Jan 8, 2007 | 08:17 PM
FastNeon84's Avatar
FastNeon84
ORIGINAL: spudsterier
the inlet and outlets come out on the side of the intercooler i have now..i cant use those little bent rubber pieces to route the piping to the back?
Old Jan 9, 2007 | 12:27 AM
Dazzellerr's Avatar
Dazzellerr
just cut the support! you want funcionallity or gofast parts? lol. i figure, if i wreck my neon it will be from some other idiot, and i will end up going to jail for kicking his butt.
Old Jan 9, 2007 | 01:28 AM
spudsterier
you might be able to use the elbows to route it.....but you will have to do a hell of alot of extra cutting and drilling
crawl underneath the front of your car and look up under the radiator......you will see all the drap that you will have to cut....in order to use a side outlet/inlet intercooer, you will have to go through some major front end supports
Old Jan 9, 2007 | 07:09 AM
FastNeon84's Avatar
FastNeon84
ok kool, well i guess i should start lookin for a srt4 intercooler then....[&:]
Old Jan 9, 2007 | 03:41 PM
spudsterier
srtforums.com
put up a wanted post....and give it a day
