I'd rather be shot in the head than have this car
Old Jan 15, 2007 | 05:26 AM
Neon_2ner's Avatar
Neon_2ner
Default I'd rather be shot in the head than have this car
Car refuses to run, even after checking all my relays, the PCM, and ignition coil, and replacing the Camshaft Position Sensor. Could the computer just need reprogramming?
Old Jan 15, 2007 | 09:21 AM
fullbuilt's Avatar
fullbuilt
Default RE: I'd rather be shot in the head than have this car
it happens if you think thats it get one from the boneyard
Old Jan 15, 2007 | 01:07 PM
spudsterier's Avatar
spudsterier
too bad you werent closer, id see if you wanna sell it
did u check the fuses???? i know you said the relays, but i thought i would ask
is the timing off?????
Old Jan 15, 2007 | 02:32 PM
das2123's Avatar
das2123
Are you not getting spark or fuel? Is it cranking and not turning over or what?
Old Jan 15, 2007 | 02:44 PM
prplhaze's Avatar
prplhaze
yea, check for spark, and fuel, then let us know..:P
Old Jan 15, 2007 | 08:41 PM
SOHC TURBO's Avatar
SOHC TURBO
same thing happened to my 96 acr...put a new computer in it...ran like a champ
Old Jan 15, 2007 | 09:20 PM
romeo21's Avatar
romeo21
check the timing belt it might be time to change it mine did that and the teeth on the timing belt were gone try thats thats an idea
Old Jan 16, 2007 | 09:38 PM
Neon_2ner's Avatar
Neon_2ner
Checked all systems, seems like we're getting fuel, just not enough pressure. It goes to the dealer end of this week, I don't feel like messing with the fuel pump assembly, I'll leave that to the pros.
