fuel pump
Old Jan 19, 2007 | 07:20 PM
javon's Avatar
javon
Default fuel pump
my car broke down because of my fuel pump l just had it rep;aced now it wont start everything is hooked up right the guy said something about there is no current what is he talking about what could be the problem
Old Jan 19, 2007 | 07:34 PM
das2123's Avatar
das2123
Default RE: fuel pump
What about the fuse and relay?
Old Jan 19, 2007 | 07:40 PM
neisg1's Avatar
neisg1
If he means no power to the fuel pump check fuse #21 (20 amp) and the fuel pump relay. They are located in the power distribution panel under the hood, just behind the battery.
Old Jan 19, 2007 | 11:26 PM
javon's Avatar
javon
i dont know what he was talking about he just said something is not getting current and i might need a computer it wont turn over
Old Jan 20, 2007 | 12:07 AM
neisg1's Avatar
neisg1
OK we're working in the dark here if you want help you need to give some basic information.
1) Was the car running property prior to the current fuel pump issue?
2) When you turn the key to start does the engine crank but not start or does it do nothing at all?
3) Is the check engine light on and if so what codes are stored?
4) What other work, if any has been done to it recently?
Old Jan 20, 2007 | 07:32 AM
javon's Avatar
javon
it was working fine before the fuel pump went out it just wont turn over i got a new aternator and a motor about 2 months ago
Old Jan 20, 2007 | 12:46 PM
das2123's Avatar
das2123
If you don't hear the fuel pump priming, check the fuse and relay. Also check the fuel pressure at the rail, should be 49psi.
Old Jan 20, 2007 | 03:48 PM
neisg1's Avatar
neisg1
Correct me if I am miss interpreting what you said “it just won’t turn over” but do you mean that the engine literally does not turn when you engage the starter? Because it that is the case ithas nothing to do with the fuel pump problem or the computer and is a starter system problem.
