98 neon wont start
Old Jan 20, 2007 | 04:47 PM
kevinwt's Avatar
kevinwt
Default 98 neon wont start
if the camshaft sensor is bad will it prevent it from firing?
Old Jan 20, 2007 | 06:07 PM
neisg1's Avatar
neisg1
Default RE: 98 neon wont start
According to the thread link below is should run but not properly with a bad cam sensor.
you should also be gettinga cel code 11 or the "P" codes if using a code scaner.
[ul][*]11 - No crank reference signal at the Powertrain control Module (PCM).[*]11 (P1390) - Timing belt skipped one tooth or more.[*]11 (P1391) - Intermittent loss of Camshaft Position Sensor (CMP) or Crankshaft Position Sensor (CKP). [/ul]
https://dodgeforum.com/m_261946/mpage_1/key_/tm.htm
