code 43
Old Jan 24, 2007 | 04:52 PM
lacombisfast's Avatar
lacombisfast
Default code 43
if anyone could help it would be greatly appreciated. I have a 98 neon DOHC i just started driving it again after having it sit for over a year. i did a complete tune up on it plugs, wires, etc. last night i was driving and it started sputtering and the power cut down. this morning i went diagnose the fault and it wont start. i have fuel but i cant check for spark i have no tools here my tools are completely across town. im thinking it might be a coil pack but if someone has any other ideas please let me know.
Old Jan 24, 2007 | 05:35 PM
das2123's Avatar
das2123
Default RE: code 43
The Code 43 is single or multiple cylinder misfire. What kind of plugs did you put in there? Inspect your work and make sure the wires are on correctly. Also inspect the coil pack for any cracks.
Old Jan 24, 2007 | 05:44 PM
lacombisfast
Default RE: code 43
i used NKG at .035 gap
Old Jan 24, 2007 | 05:57 PM
das2123's Avatar
das2123
Default RE: code 43
Good. Check the wires and coil pack.
Old Jan 24, 2007 | 07:14 PM
lacombisfast
Default RE: code 43
ok i just got a new coil pack i have spark but still wont start. it did start for a minute then shut off the spark plugs were oily and really soaked in gas
Old Jan 24, 2007 | 07:44 PM
das2123's Avatar
das2123
Default RE: code 43
You may have a headgasket leak. I'd start with some frech spark plug tube seals first and a new valve cover gasket.
Old Jan 24, 2007 | 08:30 PM
lacombisfast
Default RE: code 43
that will prevent it from runnning? what about a O2 sensor or a TPS
Old Jan 24, 2007 | 08:31 PM
lacombisfast
Default RE: code 43
and now i dont have any fuel pressure
