Not nessisarly nessisary.
Old Jan 31, 2007 | 05:12 PM
HabitatHxC's Avatar
HabitatHxC
Default Not nessisarly nessisary.
So Im looking to get rid of anything in the engine compartment that isnt nessisary for the motor to run, With HEAT. Has anyone delt with a EGR blockoff? What about PVC, What other things can be removed to prevent unsessiary problems. I want to have Motor under my hood, so if something goes wrong, its easyer to pinpoint. It may sound like a lame idea, but With less electrical bobble Things are easyer to diagnose.
Old Jan 31, 2007 | 06:11 PM
prplhaze's Avatar
prplhaze
Default RE: Not nessisarly nessisary.
Yea..block off the egr, car will run cleaner, but your check engine light will stay on, unless you can trick it with resister or something. Another thing you can do is remove your old air intake tube, and get a cai.Then you will have easy access to your headers, alternator adjustment, etc..etc.. you can also take off the weatherstripping that just slides on by the bottom of windshield...all I can think of for now..gl
Old Jan 31, 2007 | 06:51 PM
romeo21's Avatar
romeo21
power stering and a/c and if you want more room under the hood you can relocate your battery to the trunk thats all i can think of right now good luck
Old Jan 31, 2007 | 06:59 PM
das2123's Avatar
das2123
ORIGINAL: romeo21
All of that removed frees up so much room in the engine bay it's unreal.
[IMG]local://upfiles/33897/85ED4C2110544156ADEEBB9ACDAB0C52.jpg[/IMG]
Old Feb 2, 2007 | 07:26 AM
HabitatHxC's Avatar
HabitatHxC
Isnt The EGR blcokoff Blocking off two holes? One in the back, And one in the throttle body? Ive seen a penny used on one of the holes, And the other was A piece of aluminum with the stock gasket. Asfor the PVC has anyone heard or seen this done?
Old Feb 2, 2007 | 12:46 PM
das2123's Avatar
das2123
You can block off the EGR with a nickel and quarter, I think.
What about the PVC?
Old Feb 2, 2007 | 02:30 PM
HabitatHxC's Avatar
HabitatHxC
My friend That races circle track took his PVC PCV or PBS whatever it is, out. And I dont see him much anymore to ask what it does, what benifits he gets from it, Any ideas?
Old Feb 2, 2007 | 02:40 PM
das2123's Avatar
das2123
ORIGINAL: HabitatHxC
Read up...
http://www.misterfixit.com/pcvvalve.htm
Old Feb 3, 2007 | 12:39 AM
Dazzellerr's Avatar
Dazzellerr
you could read my project log for some good info.
Old Feb 3, 2007 | 07:39 AM
FastNeon84's Avatar
FastNeon84
where is the pcv valve located?
