redline at three and a half?
Old Feb 2, 2007 | 04:59 AM
mrpeyton's Avatar
mrpeyton
Default redline at three and a half?
okay i have this neon and it got into an accident and it runs now but it will not go above about three and a half grand, it sounds like its hitting a rev limiter and it starts kinda hard for like three seconds.... anyone have any clue? i think it might be vac but i hear no whining from hoses... im clueless? should i check into the vac lines or is there something else it could be thats easier to check?
Old Feb 2, 2007 | 05:12 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: redline at three and a half?
dont know what it sounds like maybe it is hitting the limiter and the tac is off?
Old Feb 2, 2007 | 07:29 AM
FastNeon84's Avatar
FastNeon84
sounds computer-related....your car throwing any codes? if so go to advance and see what the diagnostics say
Old Feb 2, 2007 | 10:56 PM
Bullet01's Avatar
Bullet01
Im with fastneon84. It sounds like a comp problem. I had a saturn that did the same thing and i had to put a new comp in it, and thats how i got my neon. Big step up in my mind.
Old Feb 3, 2007 | 08:48 AM
FyreDaug's Avatar
FyreDaug
a neon and step UP dont belong in the same sentance, regardless of the other car
Old Feb 4, 2007 | 08:21 PM
mrpeyton's Avatar
mrpeyton
yeah i had the code ran and it said my map voltage is too high but i dont think that would do it and i got to thinking maybe the cat is pluged?
Old Feb 4, 2007 | 08:44 PM
DOHCgarrett t3
so a neon isint a step up from a mini van???
Old Feb 4, 2007 | 08:59 PM
FastNeon84's Avatar
FastNeon84
nah man....minivans are much better to hook up performance wise!!
NOT!!
Old Feb 8, 2007 | 02:20 AM
tdizz07's Avatar
tdizz07
http://www.hondamarketplace.com/zerothread?id=1860138i would call that van a step up from my neon
Old Feb 8, 2007 | 06:05 PM
racerx55's Avatar
racerx55
If the map sensor is way off it wont give it the right amount of fuel and it wont run right, try a new map sensor first.
