engine comp.
Old Feb 4, 2007 | 01:36 PM
highlinedodgeneon's Avatar
highlinedodgeneon
Default engine comp.
i would like to get opinions on the motor ihad built. its a 2.0L sohc, bored and honed .030 with keith black pistons 10.4:1 comp and hastings file fit rings, reconditoned crank and rods. as for the cylinder head, decked .010 5 angle valve job, standard size valves, crane #10 cam with crane valve springs and retainers. i was told by a few guys i work with that i should see around 200 hp at the wheels, can anyone tell me it they are full of it or they are actually pretty close.
thanks
adam
Old Feb 4, 2007 | 02:18 PM
spudsterier's Avatar
spudsterier
Default RE: engine comp.
the compression would help get you more power, but the camisnt far from stock
Old Feb 4, 2007 | 04:35 PM
FastNeon84's Avatar
FastNeon84
yea...why not go with a bigger cam....like the #12 or #14?
Old Feb 5, 2007 | 12:54 AM
spudsterier
if i was gonna build a motor like that, then i would of deffinately got a #14
the motor doesnt sound bad, but i dont think i can see you getting a little under 100hp increase from it
Old Feb 5, 2007 | 02:42 AM
highlinedodgeneon
i would have but my engine builder told me not to because the #14 cam he said wouldnt let me idle very nice and the other thing we looked at which i feel is often over looked is lobe separation...thats a big deal the #10 cam has a 106 lobe sep. that should give me an incredible advantage out of the hole.
Old Feb 5, 2007 | 02:54 AM
FastNeon84's Avatar
FastNeon84
only way to tell about how much you really have, and then we can probably help you better from there.
Old Feb 5, 2007 | 11:38 AM
spudsterier
ORIGINAL: FastNeon84
is it just me or are you missing a portion of your statement here
Old Feb 5, 2007 | 11:57 AM
das2123's Avatar
das2123
If you go with the Crane#10, you will regret it later on. A Crane #14's idle can be smooth if tuned correctly.
Old Feb 5, 2007 | 11:59 AM
spudsterier
if i was gonna spendalot of money on a cam, i would deffinately get one that is alot better then stock
Old Feb 6, 2007 | 08:05 PM
highlinedodgeneon
to update everyone i just had my engine dyno tuned at the crank it made 220 n/a on 93 octane. to me it sounds pretty stout n/a motor..
what might my 1/4 mile time est. be weighing 2400 lbs...14's or 13's i hope...let me know
