Please help me out!!!
Old Feb 7, 2007 | 07:53 PM
das2123's Avatar
das2123
Default RE: Please help me out!!!
ORIGINAL: IzDatAneon
So what you are saying is not only do I have to find a 95 DOHC pcm I have to find a 95 intake manifold also..
If you don't want to swap the harness in, then yes.
I know someone selling a DOHC wiring harness from a 98 DOHC engine.
Old Feb 8, 2007 | 12:15 AM
IzDatAneon's Avatar
IzDatAneon
I have the engine harness already..All I need is a 95 harness to the pcm and the 95 DOHC manifold, and I should be ok from there right??
Old Feb 8, 2007 | 12:23 AM
das2123's Avatar
das2123
If you want to use the 95 DOHC wiring harness, then you will need the 95 DOHC MTX PCM and the 95 DOHC intake manifold.
