DOHC Head
Old Feb 7, 2007 | 12:53 PM
FastNeon84's Avatar
FastNeon84
Default DOHC Head
im about to buy a dohc head from a guy on the .org, but before i do i want to know if i am gettin a deal or not....
well this is what he told me:
#4 piston their is 2 intake valves, either the 2 seals leak or the 2 valves are bad, so the head is good, just either 2 bad intake valves or 2 bad valve seals in the #4.
he said it was $100 shipped...." deal or no deal"[&:]?
Old Feb 7, 2007 | 01:16 PM
spudsterier's Avatar
spudsterier
Default RE: DOHC Head
its fairly heavy, so the shipping would be a bit expensive....
but when you get it, it might be a good idea to take it to a shop so they can magnuflux it to make sure there isnt a crack around that cylinder
Old Feb 7, 2007 | 01:17 PM
FastNeon84's Avatar
FastNeon84
so i should get it then?
Old Feb 7, 2007 | 01:18 PM
das2123's Avatar
das2123
I'd rather get a good head personally. But you may get a steal...who knows. Check his feedback in the proper forum.
Old Feb 7, 2007 | 04:17 PM
spudsterier
if i wasnt porting mine then i woulda sold it for that much.....but it doesnt have any problems and only has 80,000 miles on it
Old Feb 8, 2007 | 02:27 AM
FastNeon84's Avatar
FastNeon84
BOO![:'(]j/k... i already sent him the money, i better get it soon[:@]
Old Feb 8, 2007 | 01:41 PM
spudsterier
like i said, you should then take it to a shop and have them look it over....make sure the valve seats and everything arent messed up
Old Feb 9, 2007 | 01:19 PM
FastNeon84's Avatar
FastNeon84
yea thats the first thing im gonna do is send it to a machine shop to have it inspected and repair anything thats damaged...
so is this head swap a fairly easy job? any problems or complications i should run into?
Old Feb 9, 2007 | 01:24 PM
das2123's Avatar
das2123
The swap is pretty straightforward, same as the SOHC head just with two cams and gears now. I'm sure you know, but get some NEW head bolts...don't use your old ones.
Old Feb 9, 2007 | 01:29 PM
FastNeon84's Avatar
FastNeon84
yea....im gonna get a set of ARP head bolts....$109 on modern performance..nota bad deal
