modular? non-modular?
Old Feb 8, 2007 | 02:34 AM
FastNeon84's Avatar
FastNeon84
Default modular? non-modular?
what is the difference between the 2? i know when i replaced my clutch, it came in one whole part..looked like the flywheel was riveted to the clutch and pressure plate....so does that mean its modular or non?
also, i see a "high torque" clutch on modern performance fora pretty reasonable price... anyone know how much torque they are rated at? what about the pt clutch? think its good for about 200-275 hp?
Old Feb 8, 2007 | 02:39 AM
johnneon's Avatar
johnneon
Default RE: modular? non-modular?
all together is modular,,flywheel pressur plate and clutch seperate is non.i heard the pt clutch is good for about 300 to 325 hp my opinion is if u have to change clutches go with the pt one,,.
Old Feb 8, 2007 | 03:42 AM
FastNeon84's Avatar
FastNeon84
ok kool, so how much torque would the pt clutches hold??? and are they modular?
Old Feb 8, 2007 | 11:52 AM
johnneon's Avatar
johnneon
im not sure how much torque but its the clutch of choice for neon upgrades unless u wanna spend a **** load of money,,99.9% sureits modular,,alot of the guys aroundwhere i amr running pt clutches and do really well,,,,.
Old Feb 8, 2007 | 12:19 PM
das2123's Avatar
das2123
ORIGINAL: FastNeon84
I wanna say they hold up to ~250 ft/lbs of torque, but I am not sure on that. And yes they are modular.
Old Feb 8, 2007 | 01:55 PM
spudsterier's Avatar
spudsterier
yes the modular is one piece....
with a non modular clutch you can separately replace the clutch components.......as a modular you just have to replace the whole thing
most newer neons have a modular...
95's are non modular
i have a non modular flywheel sitting in the garage that way if i find a good clutch for the right price, then i wont have to worry about what kind it is
i got a supposed stage 1 F1 clutch off of ebay for fairly cheap.....it hold real good and hasnt slipped at all yet
Old Feb 8, 2007 | 05:13 PM
tdizz07's Avatar
tdizz07
if you have a 95 which is non modular could you put in a modular clutch?
Old Feb 8, 2007 | 06:02 PM
racerx55's Avatar
racerx55
You can, it'll go right in, you just have to get an automatic flexplate (flywheel) to bolt it to, and the shorter flywheel bolts for the thinner plate. They bolt onto the auto flexplate just like a torque converter.
Old Feb 9, 2007 | 01:15 PM
FastNeon84's Avatar
FastNeon84
ORIGINAL: spudsterier
yea i saw it....rated for 230 hp, 210ft/lbs of torque
$178+shipping
http://cgi.ebay.com/ebaymotors/F1-RA...spagenameZWDVW
not bad...thats what i might get...
Old Feb 9, 2007 | 09:11 PM
spudsterier
yep thats the one.......it is a real good clutch and holds strong
