i need everyones help
Old Feb 12, 2007 | 05:05 AM
romeo21's Avatar
romeo21
Default i need everyones help
ok i have a 96 neon two door sohc we will call that car car.A then i have a 95 neon four door sohc we will call this one car.B ok so car .A has a hole in the block i think on pistion 1 or 2 the head is still good so i have reason to believe ok now on to car.B this car i have been told has a bad head but i have also been told that there might be a chance to that the crank shaft is broken in half (is that even possible) ok now that you have a little background on the cars i need to put the block from car.B and the head from car.A together is this possible and if the craank is broken can i change it from car.A if any one can help i would really appreciate it and sorry for it being so long
Old Feb 12, 2007 | 06:51 AM
FastNeon84's Avatar
FastNeon84
Default RE: i need everyones help
[sm=huh.gif]
Old Feb 12, 2007 | 08:19 AM
racerx55's Avatar
racerx55
Stick a few periods and capitols in there to make it easier to read for one.
The 95 motor has to use the 95 head. The one way to tell is the 95 has a steel valve cover.
The 96+ has an aluminum valve cover. 95 is the only year you cant mix & match with.
If you have a later 95 it might have the 96 style engine and it would be interchangeable.If your car says it a 95 , but has a 5 lug, you most likely have the 96+ engine. If it has 4 lug its definately a 95 and gonna have the older style motor. Ive found 5 or 6 neons like that already.
Theres holes in the block and head on the 95 that are different for the crackcase ventallation system.
Oh BTW i bet its #1 rod
Old Feb 12, 2007 | 02:46 PM
das2123's Avatar
das2123
Buy a complete 97-99 DOHC engine, harness and PCM and drop it into the 95.
Old Feb 12, 2007 | 05:11 PM
romeo21's Avatar
romeo21
well on the vin of the 95 the last 6 didgets are 500203 the valve cover look like this should it be a problem or do you think its possible
the picture is from spudster hope you dont mind
Old Feb 12, 2007 | 05:55 PM
das2123's Avatar
das2123
The last 6 digits of the vin is just the production number, doesnt mean anything else. Spud's valve cover in the pic is from a DOHC and that won't fit on the SOHC.
Old Feb 12, 2007 | 09:07 PM
romeo21's Avatar
romeo21
didnt know it was a doch i missed that but ti look kinda like that and the last 6 are what number car it was that came off the line
Old Feb 13, 2007 | 12:52 AM
das2123's Avatar
das2123
ORIGINAL: romeo21
Yes. Check the 8th digit in the vin#, if its a "Y" then its a DOHC, if its a "C" then its a SOHC.
Old Feb 13, 2007 | 04:41 AM
romeo21's Avatar
romeo21
yeah its a sohc well at least thats whats in it but can i put the head from a 96 (there both soch) on the block from a 95 and if the crank is broke (is that even possible) can it be replaced
Old Feb 13, 2007 | 11:37 AM
das2123's Avatar
das2123
ORIGINAL: romeo21
You can swap the head, just make sure to keep the same valve cover on it as they are different. You can replace the crank...it's a lenghty process, but it can be done.
