Deleting oil
Old Feb 13, 2007 | 05:03 AM
HabitatHxC's Avatar
HabitatHxC
Default Deleting oil
Well my oil is delete-ing itself, AndI dont smell burnt oil, I dont have any "visible" leaks, Is it just deleting itself? lol "Delete" ctrl, alt, Delete! But seriously where is it goin, or should i ask how long should a quart last on a nice running machine??
Old Feb 13, 2007 | 08:29 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: Deleting oil
min goes through about a quart a week i dont have any leaks myself i just assume its just burning off because of "blow by" i dont really know for sure its not uncommon
Old Feb 13, 2007 | 11:46 AM
das2123's Avatar
das2123
You probably have some leaky piston rings and your oil is blowing by and burning off. Watch your oil level.
Old Feb 13, 2007 | 06:11 PM
HabitatHxC's Avatar
HabitatHxC
I can generally tell when i need to put it in, cause the valve train makes alot of noise!
Old Feb 13, 2007 | 06:16 PM
highlinedude's Avatar
highlinedude
cheep way to find out. get oil die and put it in your oil. drive a round 1-3 days get a black light and look for die you wont miss it
Old Feb 13, 2007 | 07:17 PM
DOHCgarrett t3
cheap way is just forget about it and just add a quart a week or 1 every 2-3 tanks of gas
Old Feb 13, 2007 | 07:59 PM
shnormo's Avatar
shnormo
Pull your spark plug boots out, is there oil in there? Could be a valve cover gasket, could be intake, could be worn piston rings, bad valve guides, etc.
