piston question
Old Feb 14, 2007 | 11:06 PM
spudsterier's Avatar
spudsterier
Default piston question
so, im gonna order my pistons/ rods....now my question is which would be better.
JE .20 over bore 8.8:1 comp.
or
wiseco .40 over bore 8.8:1 comp.
either way i would be using eagle 3-D, H beam rods
ive said before that i wanna get the most out of my motor....i woud like to run 15-20psi of boost
Old Feb 15, 2007 | 12:58 AM
DNeon's Avatar
DNeon
Default RE: piston question
do they make cylinder sleeves for the 2.0? dun you increase the risk of your pistons goin thru the blockthe more you bore it?
Old Feb 15, 2007 | 01:21 AM
das2123's Avatar
das2123
ORIGINAL: DNeon
Our block is cast iron, not weak aluminum like some cars. We don't need cylinder sleeves.
Spud, I'd stick with the 0.20 JE pistons.
Old Feb 15, 2007 | 03:04 AM
dtjackten's Avatar
dtjackten
2nd gen neon peace keeper
agreed .20 over, if u dont want to have to worry about it, the cylinder walls would be very thin if u go with .40 over.....loosing dependability
Old Feb 15, 2007 | 03:08 AM
FastNeon84's Avatar
FastNeon84
how much are you paying for the piston/rod combo?
Old Feb 15, 2007 | 12:41 PM
spudsterier
ebay has a few sets of JE pistons, eagles rods, and JE piston rings for about 750.00
im gonna order them in a few minuites
im gonna go to a shop today and see what its gonna cost for the motor to get bored and honed, and everything installed
dumb question:
is it absolutely necessary that you get adjustable cam gears for aftermarket cams??? i figure it is, i just wanna figure out what kid of a small fortune i am gonna spend on this car over the next 2 weeks
another question:
anyone know of a high volume oil pump????
Old Feb 15, 2007 | 12:47 PM
FastNeon84's Avatar
FastNeon84
isnt the one they sell on modern performance a HV oil pump? its 89.99
Old Feb 15, 2007 | 12:54 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
dumb question:
No its not necessary at all. Just nice to have.
Old Feb 15, 2007 | 01:27 PM
spudsterier
well im gonna order my pistons/rods/rings now and then tonite i hope to get my cams....then maybe tomorrow i will order my oil pump and valve springs
then nextweekend i will order my srt fuel injectors, hahn map clamp, head gasket set, bearings, stainless steel brake lines, kyb gr-2's and maybe an LSD (i know im gonna need one after all this[&:])
Old Feb 15, 2007 | 01:50 PM
das2123's Avatar
das2123
kyb gr-2's
What about the Koni's??
