Just bought a neon!
#21
#22
RE: Just bought a neon!
ORIGINAL: art02gt
What is a PCM and how do i do this?
ORIGINAL: das2123
I don't think you need to replace them. I'd inspect the wiring first. Did you try to reset the PCM and see if the codes come back?
Take some time and read thru the 1st Gen FAQ's up top. Good info in there.
#23
ORIGINAL: das2123
Its your neons computer...Powertrain Control Module. Pull the fuel pump fuse in the Power Distribution Center (PDC) for about 5-10 minutes or disconnect the negative terminal on your battery for about 5-10 minutes.
ORIGINAL: art02gt
ORIGINAL: das2123
#24
