HELP Broken PCV Tube
Old Feb 21, 2007 | 08:33 PM
xlogix's Avatar
xlogix
Default HELP Broken PCV Tube
upon inspecting my engine bay today i noticed that the PVC tube below the coil pack is completely cracked off...just by looking at it i know its very brittle and trying to cut it to put it back on wouldn't work. is this something that needs to be hooked up and if so how can i get this fixed
Old Feb 22, 2007 | 12:48 AM
das2123's Avatar
das2123
Default RE: HELP Broken PCV Tube
Take it off and take it to an autoparts store and ask them for some rubber hose the same length and diameter and install it. Simple!
Old Feb 22, 2007 | 01:10 PM
asbel's Avatar
asbel
lol the same thing happened to me it. when i replaced my valve cover gasket a couple of months ago, it started splitting the hose where you're talking about so i did a quick fix wrapped the splitting end in duck tape and put one of those hose clamps around it. no preoblems so far.
Old Feb 22, 2007 | 01:41 PM
das2123's Avatar
das2123
^^^Spend the $2 and get some new hose.
Old Feb 22, 2007 | 06:38 PM
asbel's Avatar
asbel
lol im a college student. i probably should tho with 203000 miles it treats me well i should do the same in return.
