does anyone know where i can get stock real control arms for a 98 NeonR/T?
Do all the neons have the same rear control arms?
Is anyone here selling rear control arms? all 4
Ok i need help. what do you call this? these are aftermarket i need the stock ones. and my question is are these all the same on the neons. does it matter if they aredisk or drum brakes in the rear. SPC Performance EZ Arms XR Control Arms
dude thankyou you are the man. you have given me the greatest news. im gonna fabricate what you see above with the stockl ones its so easy and hella cheap. the ones above cost 160.00 each the junkyard will sell at most 20.00 per arm and the shop will charge me 40 per arm to make them adjustable. im gonna search more shops see if i could get it dome cheaper thought but so far so good. thank a million man.....
by the way for all of you that read this is a hella cheaper way to adjust your camber +3 or -3 degrees. so you can slam your neon!!! all those scrw kits wont work if you are more that 1inch drop.
