Bad Oxygen Sensor?
Old Feb 23, 2007 | 02:23 AM
art02gt's Avatar
art02gt
Default Bad Oxygen Sensor?
Somy car is throwing a code that says high input in O2 sensor.I went under my car to check which of the two was the problematic one. From what I understand the sensors should be between 5 and 7 homs. The one after the cat was fine, but the one before the cat was reading 7.8 ohms. The sensor is $80,I want to know if replacing it will solve the problem.
Old Feb 23, 2007 | 02:30 AM
NEONRT98's Avatar
NEONRT98
Default RE: Bad Oxygen Sensor?
I woudl assume so. If you get the car read by an OBDII scanner by like Advance Auto or something liek that, it will tell you which sensor is bad ;-) Get under there and make sure you dont have bare wire somewhere or somthign along those lines, too!
Old Feb 23, 2007 | 02:39 AM
art02gt's Avatar
art02gt
ORIGINAL: NEONRT98
yeah i had an OBD II scanner scan it, it said it was the sensor closet to cylinder 1 or something like that,i just want to make sure replacing it will take care of the problem, don't want to spend 80 bucks for nothing. I checked the wiring and it all seemed fine.
Old Feb 23, 2007 | 02:41 AM
das2123's Avatar
das2123
Reset the PCM and see if the code comes back. If so, pull it, clean it with CRC Electronic parts cleaner on the sensor[/b] and the connections, reinstall, clear code. Then wait to see if it comes back again. If it does, replace the sensor.
Old Feb 23, 2007 | 02:53 AM
art02gt's Avatar
art02gt
ORIGINAL: das2123
I reset the PCM twice and it came back every time. I'll try cleaning it, thanks for your help.
