HELP fast
Old Feb 24, 2007 | 09:51 PM
Leonheart17240's Avatar
Leonheart17240
Default HELP fast
how the hell do you get the front engine mount off???!?
Old Feb 24, 2007 | 11:31 PM
johnneon's Avatar
johnneon
Default RE: HELP fast
i hope this helps,,good luck,,http://www1.autozone.com/servlet/UiB...3d8019884b.jsp
Old Feb 25, 2007 | 12:00 AM
spudsterier's Avatar
spudsterier
i didnt read the link but, it is easiest if you remove the fans from the radiator....
there are 2-13mm bolts on the front of the motor under the starter......1-18mm bolt to the right of those....and 2-18mm or 15mm bolts on the bottom side of the motor.....
then remove the long bolt from the rubber bushing of the mount and then just weezel it out.....
then, if you are wanting to remove the whole rubber part of the mount thats on the car, there is 1-15mm bolt on the bottom of the radiator support thats inside the big solid metal support gaurd(bump stop)....then under that there are 2 more bolts.....unbolt them and the front piece is off
Old Feb 25, 2007 | 12:29 AM
Leonheart17240
I mean the rubber part inside.
Old Feb 25, 2007 | 03:20 AM
johnneon's Avatar
johnneon
y the rubber part,,,?if it isnt any good u change the motor mount itself,u cant just change the rubber,u can buy inserts for it,,unless ur using hockey pucks than u have to put a little gas or lighter fluid on it and melt it,,,,if thats not the answer ur looking 4 give me a lil more info on what u plan to do and i will try to help u the best i can,,,
Old Feb 25, 2007 | 10:26 AM
racerx55's Avatar
racerx55
You can just change the rubber, they sell them that way. Good luck getting it outunless you have a press.Buy the complete mount to replace it with, or get urathane inserts.
Old Feb 25, 2007 | 10:41 AM
Leonheart17240
ya i was putting hocky pucks in, i used a torch and burned the rubber out, then use my press to put the pucks in... thank for the idea johnneon
Old Feb 25, 2007 | 12:52 PM
johnneon's Avatar
johnneon
its cool[sm=icon_rock.gif],,,,,,,let me know how it goes,,,.
