Next mod??
Old Feb 27, 2007 | 07:53 PM
das2123's Avatar
das2123
Default RE: Next mod??
The hardest part of the UDP installation is pulling the stock crank pulley off.
Installing the valve body is pretty simple.
Old Feb 27, 2007 | 09:32 PM
spudsterier's Avatar
spudsterier
i have a mopar now magazine that has a step-by-step with pics about how to install the valve body
Old Feb 27, 2007 | 09:36 PM
FastNeon84's Avatar
FastNeon84
ORIGINAL: das2123
yea u need that harmonic balancer puller thing-a-ma-jig......correct?? thats what i ran into when trying to take the block apart today....
Old Feb 27, 2007 | 10:03 PM
spudsterier
ive got the puller thats needed and it works awsome..i use it all the time...kinda pricey though
http://buy1.snapon.com/catalog/item....mp;dir=catalog
Old Feb 27, 2007 | 10:07 PM
FastNeon84's Avatar
FastNeon84
that would be a good investment if i did alot of work.....just tryin to get the damn thing off! i think advance autorents them out....ill check it out though, wouldnt be a bad idea to replace it with a udp
Old Feb 27, 2007 | 10:09 PM
spudsterier
autozone rents them too
i would send mine to you so you could use it, but i dont loan my tools out anymore, especially when they cost that much money[&:]
Old Feb 27, 2007 | 10:13 PM
ohioguru's Avatar
ohioguru
i dont know if it means anything to you but i had a long talk with some of the techs from summit racing, we discuessed mods for a sohc 96 neon, they said that what your looking for in a UDP is not worth the money........it will not give you a noticible difference unless you have forced indux......save your money and get that.....
Old Feb 27, 2007 | 10:15 PM
spudsterier
or buy a cheap one off of ebay like i did
Old Feb 27, 2007 | 10:52 PM
ohioguru's Avatar
ohioguru
figure this out for yourself......how much have you spent on mods so far......how much hp have you gained.........how close would u be to a turbo.....hope u like the answer
Old Feb 27, 2007 | 11:22 PM
das2123's Avatar
das2123
ORIGINAL: ohioguru
And the techs know some much ...you can't believe everything you hear just because someone works at a certain place. UDP's on neons have been dyno proven to show the freed up horsepower. They allow the neon to rev quicker and accelerate quicker.
