Next mod??
Old Feb 26, 2007 | 06:41 PM
QuiK615's Avatar
QuiK615
Default Next mod??
Next mod
http://www.modernperformance.com/dcx/mpx_pulleys.jpg
or
http://www.howellautomotive.com/inde...amp;ProdID=800
Old Feb 26, 2007 | 11:57 PM
das2123's Avatar
das2123
Default RE: Next mod??
Street/strip valve body...you will love it!
Old Feb 27, 2007 | 12:04 AM
spudsterier's Avatar
spudsterier
yeah i would deffinately get the shift kit.......more fun driving then just having an UDP
Old Feb 27, 2007 | 12:32 AM
godxld50's Avatar
godxld50
wow... thats what i need a shifter like that. thnx for the info..
Old Feb 27, 2007 | 03:41 AM
HabitatHxC's Avatar
HabitatHxC
or get yours recalibrated =D
Old Feb 27, 2007 | 07:04 AM
QuiK615's Avatar
QuiK615
probably going to go with both need the performance valve body for racing, and UDP is the next thing on the SOHC list plus i need new belts and a full tuneup
Old Feb 27, 2007 | 07:36 AM
FastNeon84's Avatar
FastNeon84
if you are looking for an engine, ill be selling mine when i do the swap96 sohc...engine still running strong....no valve knock.....nothing...$300 with the pcm
Old Feb 27, 2007 | 04:00 PM
QuiK615's Avatar
QuiK615
My engines doin fine for now, lol But how much of a differance will i see with the valve body? I heard the UDP gives you around the same performance boost as a CAI
Old Feb 27, 2007 | 04:55 PM
das2123's Avatar
das2123
Your shifts will be quicker as well as acceleation. You can also spin the tires alot easier.
Old Feb 27, 2007 | 07:36 PM
QuiK615's Avatar
QuiK615
How is the install on the valve body, dont know much about cars (but im learning) and i have a few mechanic friends. Theres a few posts on here reguarding the installation of a UDP and the hardest part about that is the belts so im not too worried about that.
