speedchip
Old Feb 27, 2007 | 01:41 AM
godxld50's Avatar
godxld50
Default speedchip
does anybody know if this speed chip really work or not.. i mean 20hp? for 4 bucks sounds like a deal.
http://cgi.ebay.com/ebaymotors/20HP-...QQcmdZViewItem
Old Feb 27, 2007 | 01:55 AM
neoncrazy101's Avatar
neoncrazy101
Default RE: speedchip
nope not good at all. only speed "chips" that work are the Mopar Performance PCM (whole new PCM) or the AF/x(?) from Howell.
Old Feb 27, 2007 | 02:13 AM
godxld50's Avatar
godxld50
any links?
Old Feb 27, 2007 | 02:22 AM
neoncrazy101
Mopar Performance
http://www.modernperformance.com/dcx/mopar_pcm.shtml
AF/x
http://www.howellautomotive.com/inde...p;Category=215
the Mopar one is the one i would get though. its cheaper and IMO its better.
Old Feb 27, 2007 | 12:41 PM
das2123's Avatar
das2123
ORIGINAL: neoncrazy101
Mopar Performance
AF/x
Your opinion would be way off then. The AF/x Race version is better than the Mopar PCM, but the street version isn't much better than the Mopar.
Old Feb 27, 2007 | 06:08 PM
FastNeon84's Avatar
FastNeon84
i think i bought that thing before a long time ago....crap dont work. dont do anything but make your car run like crap and throw engine codes. IF it was true....they would post some sort of before-after dyno sheets showing a gain of 20hp. and they charge you $4 to ship it even though it comes in a .39stamped envelope.
Old Feb 28, 2007 | 12:44 AM
NEONRT98's Avatar
NEONRT98
You know there is alot of handling involved in that delicate, fragile little resistor...
Old Mar 2, 2007 | 03:21 PM
ryleynoyes's Avatar
ryleynoyes
www.mopartsracing.com cheapest mopar perf. parts i've found. mopar ecu is about 185
Old Mar 3, 2007 | 03:13 AM
das2123's Avatar
das2123
ORIGINAL: ryleynoyes
ENGINE CONTROLLERS
5007033 1995 SOHC manual trans 239.00 5007035 1996 SOHC manual trans 245.00 5007037 1997/99 SOHC manual trans 245.00 5007034 1995 DOHC manual trans 239.00 5007036 1996 DOHC manual trans 245.00 5007038 1997/99 DOHC manual trans 245.00
WHICH ONE IS $185????
