stud kits
Old Feb 27, 2007 | 11:11 PM
das2123's Avatar
das2123
Default RE: stud kits
ORIGINAL: spudsterier
im just curious if they will still work on the 2.0
Same head, so they should work.
Old Feb 28, 2007 | 12:19 PM
spudsterier's Avatar
spudsterier
ok then because im gonne need to order some here soon.
Old Feb 28, 2007 | 12:52 PM
das2123's Avatar
das2123
Yep, confirmed it last night. Will work on both heads.
Old Feb 28, 2007 | 02:01 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
are they easy to install? i dont know if i need them i wont be tearing it apart that often
Old Feb 28, 2007 | 03:47 PM
das2123's Avatar
das2123
ORIGINAL: DOHCgarrett t3
The head bolts? Yes, you just need to torque them down in the correct sequence and you should not reuse head bolts.
Old Feb 28, 2007 | 08:35 PM
rtneon67's Avatar
rtneon67
how do u tourge down the studs those i kno u can use a tourge wrench for the nuts but what about the studs that go into the block
Old Feb 28, 2007 | 10:48 PM
spudsterier
put the nuts on and torque them down
