Gas Pedal
Old Mar 2, 2007 | 12:02 AM
art02gt's Avatar
art02gt
Default Gas Pedal
I've noticed that my gas pedal gets stuck sometimes. It does it when when I'm slowing down and let go of the gas pedal. When I try to accelerate, I can't press it, I have to hit it a couple of times before I can press it normally. What can be happening?
Old Mar 2, 2007 | 05:40 AM
asbel's Avatar
asbel
Default RE: Gas Pedal
i dont know if its the same problem but once in a while ill be driving fine then i let off the gas completely. then i go to push down and its as if it is stuck so i have to give it a few taps with my foot. i dont know what would happen if i just pushed hard on it. i dont think this helps in any way but im here to let you know you're ot the only one and i hope to get to the bottom of this too.
Old Mar 2, 2007 | 07:55 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
well theres no way to tell really where its happening. do you have cruise control? check your pedal area maybe your floor mat has cought the peddal. or under the hood check the throttle body. with car off remove cover and dissconnect cable and open it a few times and let it close on itself
i remember the older saturns dont know what make or model the peddal would stick when at idle (say at a stop light or something) and when you pressed it it would stick at first.
Old Mar 2, 2007 | 11:59 AM
hnda8r's Avatar
hnda8r
Usually when your pedal get sticky like that, it means you have to clean your throttle body out. Try that first, then we can go from there.
Old Mar 2, 2007 | 12:09 PM
spudsterier's Avatar
spudsterier
i had a problem where i would really get on the gas and when i would let off to shift, the pedel would go to the floor and cause the motor to just keep bouncing off the rev limiter.....then i noticed that the pedel was getting cought under the floor mat[:@]
Old Mar 2, 2007 | 12:41 PM
hnda8r's Avatar
hnda8r
^^ Thats kinda funny, but also very dangerous[]
Old Mar 2, 2007 | 03:53 PM
spudsterier
yeahi know....luckily whenever the car would do this i would just throw it into neutral and turn off the key[&:]
Old Mar 2, 2007 | 06:00 PM
art02gt's Avatar
art02gt
ORIGINAL: DOHCgarrett t3
Yeah I have cruise control, but it doesn't work [&:],and the throttle body is a bit dirty, what do I clean it with? Carb Cleaner?
Old Mar 4, 2007 | 08:50 AM
DOHCgarrett t3
seafoam
Old Mar 4, 2007 | 09:22 AM
DOHCgarrett t3
ORIGINAL: hnda8r
kinda like when the beer bottle rolls under the brake peddel too heh heh heh
