97 neon sohc turbo help
Old Mar 2, 2007 | 10:59 PM
juggalopanther1's Avatar
juggalopanther1
Default 97 neon sohc turbo help
hi, I'm kinda new at this. I'm in the process of turbo charging my 97 neon SOHC. I have a rb20 turbo and having trouble making a pipe that goes from the turbo to converter (any suggestions), the other ? is I am thinking about running a fmu for the fuel. Does anyone know how to hook it up. PLEASE HELP
Old Mar 2, 2007 | 11:34 PM
turbodneonracer96's Avatar
turbodneonracer96
Default RE: 97 neon sohc turbo help
The Fmu is used to controll your fuel return! Do you know where you fuel rail bleader is. If you do hook up a hose to that then your fmu. Then from the fmu to the gas tank return line.
Old Mar 2, 2007 | 11:36 PM
turbodneonracer96
Also to control fuel flow and pressure you can save money by getting a 20.00 fuel regulator. u can also use a fuel regulator as an fmu.
Old Mar 3, 2007 | 12:07 AM
juggalopanther1
if I buy a fuel regulator what should I set it at?
Old Mar 3, 2007 | 12:54 AM
spudsterier's Avatar
spudsterier
i actually had mine set in the begining at about 60psi....then worked my way up to about 80....
Old Mar 3, 2007 | 07:03 AM
FastNeon84's Avatar
FastNeon84
dont go cheap on fuel pressure regulators...get a good one....may cost a bit but will help out alot.....
Old Mar 3, 2007 | 10:33 AM
racerx55's Avatar
racerx55
FPR's with a 1:1 rising rate work really nice.You should also look into a wideband air / fuel ratio meter, wideband only. theyre not cheap. keep your a/f ratio 11.0:1 at WOT with a turbo if you want your engine to last a good long time.Youll lose a few HP running that rich but save your engine bigtime.
Old Mar 3, 2007 | 12:00 PM
spudsterier
ORIGINAL: FastNeon84
thats funny since i told you that a while back...
ive got a nice aeromotive 1:1 on ebay...ends sundayevening if your interrested
Old Mar 4, 2007 | 12:03 AM
juggalopanther1
I'm bidding on your aeromotive regulator right now. I'm under my sister in laws name on ebay. Thankx for the heads up...
Old Mar 4, 2007 | 07:03 AM
FastNeon84's Avatar
FastNeon84
ORIGINAL: spudsterier
i only learn from the best!
