Dirty Intake Manifold
Old Mar 3, 2007 | 03:07 PM
art02gt's Avatar
art02gt
Default Dirty Intake Manifold
For some reason my intake manifold is really dirty. I think it might have been from when the head gasket was leaking oil. It looks like black sludge, not much though, just a thin layer of it starting from the throttle body and in to the intake manifold. How can I clean it out? Carb cleaner? Sea Foam?
Old Mar 3, 2007 | 04:15 PM
AIRBORNEREY578's Avatar
AIRBORNEREY578
Default RE: Dirty Intake Manifold
carb or intake cleaner. its sold at advanced or any parts store, walmart,and k-mart....
Old Mar 3, 2007 | 06:15 PM
mmench's Avatar
mmench
the black stuff inside the manifold prolly from the egr
Old Mar 3, 2007 | 06:40 PM
art02gt's Avatar
art02gt
ORIGINAL: mmench
egr?
Old Mar 3, 2007 | 06:43 PM
mmench's Avatar
mmench
yea. the little pipe that goes from exhaust manifold to the intake manifold just under the throttle body. it reciculates exhaust for some kinda emision thing. not really sure wat it all entails
Old Mar 3, 2007 | 07:22 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
if you dont have Emissions testing in your state or area you can remove the egr system then you wont have to worry about this problem and use the sea foam
Old Mar 3, 2007 | 09:48 PM
das2123's Avatar
das2123
What the others are saying is true about the Exhaust Gas Recirculation (EGR) valve, but if you do block it off, you will constantly have a CEL for it unless you have an aftermarket PCM.
