Cruise Control
Old Mar 3, 2007 | 03:43 PM
art02gt's Avatar
art02gt
Default Cruise Control
The cruise control on my car doesn't work. Is this common? What could be the problem?
Old Mar 3, 2007 | 08:40 PM
neisg1's Avatar
neisg1
Default RE: Cruise Control
If this is on a 95 the cruse control vacuum transducer is located under the battery, on later models it was up top behind the battery. There are vacuum line from the transducer to a rectangular plastic box vacuum reservoir located in front of the wheel under the bumper cover and fender. Check the box and vacuum lines, the box went missing on mine due to road debris or possibly an encounter with a snow drift.
Old Mar 3, 2007 | 09:46 PM
das2123's Avatar
das2123
The cruise control servo is in the same place for all 1st gens
Old Mar 3, 2007 | 10:49 PM
neisg1's Avatar
neisg1
ORIGINAL: das2123
The attached link is a photo of a 96 Neon cruse servo http://i2.tinypic.com/4532fqr.jpgand I know for a fact that my 95 Neon has it mounted under the battery. My 95 was an early model built in 1994 if that makes a difference or possibly manual vs auto trans?
I just went out and looked at mine and it is under the battery.
Old Mar 3, 2007 | 11:03 PM
johnneon's Avatar
johnneon
ORIGINAL: das2123
On my 95 it was under the battery 2,,,!!!!!Das2123 if u dont really know y argue!!!!!
Old Mar 4, 2007 | 11:45 AM
das2123's Avatar
das2123
Ahhh...I was thinking of the vacuum reservoir.
