battery light ON
Old Mar 8, 2007 | 02:36 PM
starik's Avatar
starik
Default battery light ON
i've made repairs to wiring harness for + terminal (it broke due to bad corrosion). Trouble is, i didnt use wire thick enough. When i cranked the engine, was a big poof! and my handiwork disintegrated.
Then I've fixed it all up good. Car could start on its own, but the battery light came on the guage cluster.
I drove it for a couple of days like that, while waiting for weekend but the car didnt start this morning. Battery dead. I can jump-start the car no problem.
I figure since after the incident, the battery is not being charged anymore.
What did i fry? what to check? If something major like alternator was dead, the car wouldnt start at all, right?
Old Mar 8, 2007 | 02:46 PM
das2123's Avatar
das2123
Default RE: battery light ON
If the car starts with a jump, then the battery is what I would check first. Then look at the alternator. Autozone does a free battery check for you.
Old Mar 8, 2007 | 02:47 PM
shnormo's Avatar
shnormo
You prolly blew the regulator or a diode in the alternator.
Old Mar 8, 2007 | 02:49 PM
starik's Avatar
starik
after i jump-started, i drove the car for like 10 minutes and battery did NOT charge at all.
so you are saying the car can run even with toasted alternator?
please tell me how to check alternator.
thanks
Old Mar 8, 2007 | 02:54 PM
das2123's Avatar
das2123
Yes the car will run with a bad alternator, but it won't charge the battery at all.
Old Mar 8, 2007 | 02:56 PM
starik's Avatar
starik
regulator: i dont know what it is. where do i find it (in service manual or car itself)?
diode in alternator: is that replaceable or do i need to replace the whole alternator?
Old Mar 8, 2007 | 02:59 PM
das2123's Avatar
das2123
You would need to replace the whole unit. It is serviced only as a complete assembly. If the generator
fails for any reason, the entire assembly must be replaced.
Old Mar 8, 2007 | 03:00 PM
shnormo's Avatar
shnormo
Everything is internal. That would be replacing the whole thing.
Old Mar 8, 2007 | 04:35 PM
starik's Avatar
starik
how would you rate the difficulty of removing/installing alternator (or as manual calls it, generator)? I dont have torque wrench or belt tensioner tools. Just basic socket wrench set.
does the vehicle really need to be lifted up?
Old Mar 8, 2007 | 04:46 PM
das2123's Avatar
das2123
Not real difficult at all. I just posted a how-to in this thread...
https://dodgeforum.com/m_728575/tm.htm
