swap by year
Old 03-23-2007, 07:46 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
Default RE: swap by year
i dont know if the sensors will fit exactly....but you will have to change ALL of them
  #22
Old 03-24-2007, 01:07 AM
romeo21's Avatar
romeo21
romeo21 is offline
can i just take them off the old motor and put them on the new one or do i have to buy all new sencers
  #23
Old 03-24-2007, 01:35 AM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: romeo21
ok will all the sencers fit on that new motor and what sencers do i have to replace
Which ever ones will not plug into your 96 harness. Probably the coolant temp sensor and maybe the knock sensor and your 96 injectors. You can probably use the 2nd gen fuel rail.
  #24
Old 03-26-2007, 10:52 PM
romeo21's Avatar
romeo21
romeo21 is offline
ok can i use the 96 cluch or should i buy a cluch for a 2000 and if so what stage should i get and one more question the motor mount on the passanger side is shot dose any one make a proformance mount or do i start looking at junk yards
  #25
Old 03-26-2007, 11:01 PM
das2123's Avatar
das2123
das2123 is offline
You can use your 96 clutch.
Deyeme racing sells motor mounts.
  #26
Old 03-27-2007, 07:22 AM
romeo21's Avatar
romeo21
romeo21 is offline
are those mounts any good is it a good idea to have aluminum mounts and how many sencers are there
  #27
Old 03-27-2007, 11:31 AM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: romeo21
They are very popular mounts with the neons. Sensors that you have to swap is about 5 or 6. It won't be that difficult. If it doesn't plug into your 96 harness, swap the plug.
Now quit asking questions and swap that bad boy in there
  #28
Old 03-27-2007, 06:44 PM
BadBrads97Neon's Avatar
BadBrads97Neon
BadBrads97Neon is offline
haha damn straight lol
  #29
Old 03-27-2007, 09:00 PM
romeo21's Avatar
romeo21
romeo21 is offline
hey thanks guys i will swap that bad boy in as soon as i get it but i have just two more questions first is i have a modular cluch do i have to use the same type of cluch are to i have to get a new one since the new mtor is a 2000 and second is if i get a udp i have to get it for a 2000 not a 96 right any part i have to get them for a 2000 and any electrical and sencers i have to get them for a 96 i hope that makes sence but thanks for all the help
  #30
Old 03-28-2007, 12:16 AM
das2123's Avatar
das2123
das2123 is offline
You can use the crank pulley from a 1st gen and use your modular clutch.
Quick Reply: swap by year
