swap by year
Old 03-16-2007, 12:28 AM
romeo21's Avatar
romeo21
romeo21 is offline
Default swap by year
ok i have a 96 neon mtx sohci have ablown motor i have found a 2000 sohc out of a neon no transmision. My question is: Will the transmision onthe 96fit on the 2000 motorand can i use the 2000s wiring harnessor do i have to use the 96 and what other parts do i need? thanks alot for the help
Old 03-16-2007, 01:27 AM
romeo21's Avatar
romeo21
romeo21 is offline
Default RE: swap by year
the motor from the 2000 is a 2.0 th guy said it was from a 2000is he right or is he trying to pull a fast one
Old 03-16-2007, 01:55 AM
neoncrazy101's Avatar
neoncrazy101
neoncrazy101 is offline
same engine. different wiring and maybe motor mounts. not sure though.
Old 03-16-2007, 02:12 AM
das2123's Avatar
das2123
das2123 is offline
It is a 2.0L SOHC engine but has some differences. The mounting system is different, accesories are in a serpentine style belt and the air intake is in a different location.
It will fit fine with your stock clutch.
Old 03-16-2007, 02:32 AM
romeo21's Avatar
romeo21
romeo21 is offline
the guy at the yard said that i just need to take off and adapter and it is ready to drop in and it looks just like my 96 motor if i can i will try to get some pictures but it looks the same the valve cover looks a little diffrent
Old 03-16-2007, 11:06 AM
das2123's Avatar
das2123
das2123 is offline
I think, you can use your current wiring harness and PCM, but you would have to swap all your sensors over. But I am not positive on this.
Old 03-22-2007, 07:04 AM
romeo21's Avatar
romeo21
romeo21 is offline
ok i am looking to swap my 96 sohc(i blow the motor on that one) and upgrade to a 2000 sohc the guy at the yard said that i have to change a motor mount and drop it in now can i use the wireing harness thats on the 2000 motor or do i need to change the wiring harness and sencers please help or tell me who to talk to to find out
Old 03-22-2007, 10:57 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
dont hold me to this but you should be able to just change the sensors and use your computer and harness....
Old 03-22-2007, 11:59 AM
das2123's Avatar
das2123
das2123 is offline
OK, after some research this is what I came up with:
To swap the 00 motor into your 96 you will need to swap sensors and brackets as needed, use your 96 intake and exhaust manifolds, your 96 wiring harness and PCM, swap the crank pulley and timing belt cover. You can also swap over your 96 valve cover.
The 00 engine also has the EGR blockoff plate on there, so you will need to remove it and install your 96 EGR on there or leave it blocked off if you don't mind the CEL or you have an aftermarket PCM.
Old 03-22-2007, 03:33 PM
spudsterier
so basically you will just be using the 00 block and head
Quick Reply: swap by year
