96 neon speedometer
Old Mar 17, 2007 | 10:47 PM
joe.l.s's Avatar
joe.l.s
Default 96 neon speedometer
Just bought a used 96 neon and the speedometer isnt working. Occasionally it pops back up and works fine.
Should I assume the gauge cluster is bad?
Where is the speed sensor on this car?
Old Mar 17, 2007 | 10:50 PM
unclemike's Avatar
unclemike
Default RE: 96 neon speedometer
Do a search, Neon Speedometer Problems you will find a thread on this problem and how to fix it. There is a printed circuit board on the back of the cluster. You take it off and remelt all the solder connections on the two plugs that go into the whireing harness.
Old Mar 17, 2007 | 10:56 PM
joe.l.s's Avatar
joe.l.s
Thanks.. Im used to another forum which only paying members can search!
Didnt know it was a fairly common problem.
