acceleration problems
Old Mar 18, 2007 | 06:17 PM
2ptycove's Avatar
2ptycove
Default acceleration problems
I have a 1996 Neon that has some acceleration problems. I have changed the fuel filter, fuel injector, all plugs & wires. The problem is sporadic. I may be driving along just fine and then start to loose power. If I let off the gas then push again it helps sometimes? Anyone with same problem or suggestions?
Old Mar 18, 2007 | 06:23 PM
DurangoDarrin's Avatar
DurangoDarrin
Default RE: acceleration problems
Check your TPS. sometimes they go bad and it isn't enough to set off the engine light. My '97 did that. Also I had a simiar problem with my '98 dohc and whenever I smacked the computer while it was running, the car would shudder and run ok for a while. I replace the computer (e-bay) for 50.00 and problem solved. Just a couple of ideas that might help.
Old Mar 19, 2007 | 12:37 AM
FastNeon84's Avatar
FastNeon84
that might be the same thing thats wrong with my car....oh yea, thatavatar is hott durangodarrin!
