Turboing a 97 DOHC??
Old Mar 18, 2007 | 11:39 PM
BadBrads97Neon's Avatar
BadBrads97Neon
Default Turboing a 97 DOHC??
Ok so I am about to have a friend of mine install a turbo kit on my car. Its a 97 DOHC with only 48k miles on the whole car. There are no problems with the car except a small leak in the oil pan which will be fixed this weekend. I was just wondering what psi I should run it at and if there are any problems with installing it on my stock engine? My friend is an expert and he works at an auto shop but I just wanted some opinions from some of you people on here because alot of you sound very intelligent and know your ****. Like I said my car is in perfect condition pretty much and I just wanted to know if there is anything I should worry or think about before I go ahead with the installation. Thanks
Old Mar 18, 2007 | 11:59 PM
das2123's Avatar
das2123
Default RE: Turboing a 97 DOHC??
Up to 7 psi on stock internals.
Old Mar 19, 2007 | 12:03 AM
BadBrads97Neon
ok and what would I have to change if I wanted to run it on more psi?
Old Mar 19, 2007 | 12:05 AM
das2123's Avatar
das2123
Pistons and rods for starters.
What all is your friend installing? What are you doing for fuel, oil and coolant lines?
Old Mar 19, 2007 | 12:14 AM
BadBrads97Neon
the kit is a complete kit. Here let me type what all comes in it.
Turbo: T3/T4 Turbo T04C Spec: * 3" inlet, 2" oulet diameter.
* Wet floating bearings 1/8 NPT oil inlet standard T3/T4 flange.
* 57 compressor wheel trim, .63 A/R turbine, .50 A/R compressor.
Manifold: Casted material, T3/T4 Turbo Flange , 35MM or 38MM Tail Wastegate Flange.
Oil lines: Feed line and drain line:36" of 3/8" stainless steel braided line with industrial crimped. 1/8" NPT male fitting goes to block of engine and - 4 AN male fitting built on the flange (comes with and screw/washers) with built in oil restrictor, flanges are used airframe grade 7075 aluminum. 4way adaptor is included with 1/8" NPT fitting and one plug to block off on port, 4-way screws into the block with male/male fitting.
Fuel System: Fuel pump: Walbro GSL392 universal inline 255LPH high pressure fuel pump and 400-939 installation kit (with instructions).
FMU Fuel managment unit: 12:1 ratio
Intercooler/ Piping: ~ 2.5" Intercooler piping with black coated JDM look.
~ Made out of high quality material.
~ Pipe thickness: 1/16 in. (1.58 mm)
~ w/ x6 Blue Silicone cupplers and x2 Elbow Silicone cupplers
~ up to 40%-60% increase flow compared to standard bent piping.
~ (x 90 Degree Pipe, x2 75 Degree Pipe, x2 45 Degree Pipe, x2 Straight Pipe).
~ With x6 Silicone Blue Hose Connector, x2 Silicone Elbow Hose
~ 3Year warranty
Intercooler: ~ All TIG Welded 6061 Aluminum All hand Welded.
~ 100% Brazed Core (No Epoxy).
~ High Efficiency Bar & Plate Construction
~ High Flow Tube & Fin Construction.
~ Core Length: 22" x 5.5" x 2.5".
~ Overall Length: 27" x5.5" x 2.5".
BOV: Greddy Type-RS Replica Blow Off Valve
~ Fully adjustable
~ Mounting/flange already pre-welded to intercooler piping.
Wastegate: Adjustable 38mm Tial Replica wastegate with flanges,8psi Spring
Gauges: Mechanical Boost Gauge with blue face and neon gauge mounting pod
- 2-1/16" size
- reads 0-30 vac and 0-30 boost
- white face
- Hardware included (vav. line/hose,fittings, and instructions)
Ok there is a "copy and paste" version of the email he sent me.
Old Mar 19, 2007 | 12:17 AM
das2123's Avatar
das2123
Not bad...how much for all that?
Old Mar 19, 2007 | 12:21 AM
FastNeon84's Avatar
FastNeon84
make sure u get a wideband a/f ratio too......got any pics of the kit?
BadBrads97Neon
1350 plus whatever shipping would cost to where you are. So other than pistons and rods what would I need to install to run at a higher psi? Oh and what would be a good psi to run at?
Old Mar 19, 2007 | 12:25 AM
BadBrads97Neon
There is one of the whole kit.
Old Mar 19, 2007 | 12:28 AM
das2123's Avatar
das2123
ORIGINAL: BadBrads97Neon
An engine rebuild would be a good idea if you wanna go over 7 psi. With improved engine internals, you could knock yourself out with the psi, but that depends on the turbo specs.
