wheel hop problem
Old Mar 19, 2007 | 02:45 AM
Newneonguy's Avatar
Newneonguy
Default wheel hop problem
ok I have anotherproblem and I did look this one up in previous threads but it is wheel hop. It looks like I can just get some Prothane motor mount inserts and it will take care of that bouncing feeling which loses all accelaration I may have in my atx neon. Is that right? cuz if its not i dont want to wastemoney on them. Alsoaparentlly my inner cv joints are badso would that have anything to do with it. shouldI get a heavy duty axel for maximum acceleration in my atx? thanks
Old Mar 19, 2007 | 11:35 AM
das2123's Avatar
das2123
Default RE: wheel hop problem
The prothane inserts help reduce wheel hop tremendously, but they will add vibration to the inside of the car. Seeing that you have an ATX, your acceleration will be slow regardless though. Here is a site you may want to look at, if you want to make your ATX faster.
http://halfahemi.com/fastatx/
Keep in mind that swapping to an MTX will make you instantly quicker.
Old Mar 19, 2007 | 02:21 PM
Newneonguy's Avatar
Newneonguy
I would love an mtx butwouldnt that cost alot to buy one and put it in?
Old Mar 19, 2007 | 02:31 PM
das2123's Avatar
das2123
ORIGINAL: Newneonguy
Not if you shop around and do the work yourself.
Old Mar 19, 2007 | 02:45 PM
Newneonguy's Avatar
Newneonguy
may have to check into that, thanks
Old Mar 19, 2007 | 02:52 PM
das2123's Avatar
das2123
If you shop around, you can get everything you would need for about $500-$600.
Old Mar 20, 2007 | 04:48 AM
racerx55's Avatar
racerx55
i have yet to see or drive an ATX neon that will even try to spin the tires unless you neutral slam it from the rev limiter[&:]
Old Mar 20, 2007 | 10:14 AM
spudsterier's Avatar
spudsterier
thats what i was thinking....wheel hop is the last thing you should ever have to worry about on an auto neon....unless its highly modded
Old Mar 20, 2007 | 11:57 AM
das2123's Avatar
das2123
My 99 would spin the tires a bit and get wheel hop. Not alot, but enough to notice. I just got a front prothane motor mount insert and it took care of it.
Old Mar 20, 2007 | 03:11 PM
spudsterier
i assume it had low miles
hey, maybe it had a shift kit
