Car won't Start with Key Please Help!!!
Old Mar 19, 2007 | 04:02 AM
elnoyl's Avatar
elnoyl
Default Car won't Start with Key Please Help!!!
My car is a 95 sohc neon sport manual. When i try to start my car with a key it just makes one click and does nothing no cranking or anything. This first happened at a friends house and i was able to push start the car and drive home just fine. The alternator is only about a year old and is brand new. The car still seems to have plenty of power in the battery because i can listen to the radio and my headlights seemed the same brightness without the car running. The starter is an original with about 127k on the odometer so i'm assuming that's the problem. The battery is also an original though. I just would like to know the best things i can do before i change the starter so i can get the problem fixed the least expensive and time consuming way. Thanks in advance.
Old Mar 19, 2007 | 04:19 AM
BadBrads97Neon's Avatar
BadBrads97Neon
Default RE: Car won't Start with Key Please Help!!!
First thing I would do is take the car somewhere and have someone, or you can check yourself, just check the battery and see if it still has enough voltage. If it does then the problem is either the starter or the alternator. Since you said the alternator is fairly new I would say its either the battery, starter or maybe some wiring. I would just take the battery and starter to say Auto Zone or somewhere like that and they can test both of them to see if they are fine.
Old Mar 19, 2007 | 04:21 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
push start the car then take the negative battery cable off to test alternator.
the only way you can have the starter tested is take it off and take it to an auto store
Old Mar 19, 2007 | 04:25 AM
elnoyl's Avatar
elnoyl
i will first try by removing the battery terminals and testing the voltage with a multimeter on the battery. Than i will clean up the terminals really well and try starting it.
Old Mar 19, 2007 | 04:39 AM
elnoyl's Avatar
elnoyl
i couldn't find my multimeter but i cleaned the terminals with a wire brush real well and the same result. I think i will just bring the battery tomorrow to get it tested. any more ideas?
Old Mar 19, 2007 | 04:51 AM
Dodge Tech's Avatar
Dodge Tech
are u getting a clink when u turn the key eash time it will clink once???
starter
Old Mar 19, 2007 | 04:56 AM
elnoyl's Avatar
elnoyl
yep only 1 click than it's dead but the accs will still work ex radio headlights etc
Old Mar 19, 2007 | 09:12 PM
Leonheart17240's Avatar
Leonheart17240
this might sound dumn but try taping it with a wrench. i had a car that would click and then nothing. i hit it and i would work.
Old Mar 20, 2007 | 12:45 AM
neisg1's Avatar
neisg1
ORIGINAL: elnoyl
As you have already checked and cleaned the battery connections, make sure the battery and ground connectionsat the starter are clean and tight. Next step would be to verify the battery condition, if it’s ok then have the starter tested.
Old Mar 20, 2007 | 03:11 AM
elnoyl's Avatar
elnoyl
today i took a pry bar and placed it on the starter and tapped it with a hammer a few times all around the starter. I than was able to start the car with the key. I turned the car off and tried to start it again and was unable to start the car and it was just one click. I'm going to replace the starter in a couple of days. How difficult is replacing the starter. I was hoping i could just remove the cooling fan and that would give me enough clearance. How many bolts and where are they located to remove the starter? any tips
