My bottom end budget build PIX ADDED!
Old Mar 23, 2007 | 11:04 AM
  #41
spudsterier's Avatar
spudsterier
Default RE: My bottom end budget build PIX ADDED!
i still wouldnt reccomend it......thats alot of compression in our little motors.....but you COULD if you wanted to...of course, if you were only gonna run 4psi, then why waste the money and time on a turbo????? just get some nice cams instead
Old Mar 23, 2007 | 12:35 PM
  #42
FastNeon84's Avatar
FastNeon84
the last thing you would want is to spend $1700 on engine work, then get the turbo and slap it on, and blow your engine in a month....if you are planning on turbo somewhere down the road, mine as well go with the low compression pistons
Old Mar 23, 2007 | 04:28 PM
  #43
BadBrads97Neon's Avatar
BadBrads97Neon
yeah just realize that 4psi is too much on that much of a compressed engine. Like spud said, you could just get some real nice cams and you would be fine.
Old Mar 24, 2007 | 07:35 AM
  #44
HabitatHxC's Avatar
HabitatHxC
I could get A cam Since its a single slam! But thats down the road, AFTER she is built. Since i already have a cam that is a tit bit better than the 95 stocker.
Still havent gotten any work done on the head, Since my father wishes for me to grind the head OUTSIDE. Since there are shiney things in the garage (H2, Harley... ect.) And this stinkin ohio weather doesnt help!
I dont see it taking more than a good days work to get the head done anyway.
Another thing, VALVE SPRINGS. Can I REUSE the stock ones? OR Where can I Find Magnum springs? (shoulda got them from das!) And will the stock retainers fit in magnum springs or willI have to get Magnum springs AND retainers?
Old Mar 24, 2007 | 12:04 PM
  #45
spudsterier
you can reuse the springs without any problems....or you could always get some crane valve springs...
i got the cranes to go with my cams...i just cant wait until its all done so i can drive it[:@]
Old Mar 24, 2007 | 02:57 PM
  #46
FastNeon84's Avatar
FastNeon84
ORIGINAL: spudsterier
you and me both.....i still need to get that bundle of stuff from ya...
Old Mar 25, 2007 | 12:14 AM
  #47
spudsterier
yes you do
ever find anything about those side skirts?????
Old Mar 25, 2007 | 06:33 AM
  #48
HabitatHxC's Avatar
HabitatHxC
I started smoothing the ports on the head, and my dremel busted! But we fixed it! its all good now! BACK TO WORK!!
Old Mar 25, 2007 | 02:43 PM
  #49
spudsterier
just make sure that you arent just grinding stuff down......you will get the best outcome if youjust gasket match the ports...intake and exhaust
what kind of bit are you using to do the grinding???
i have found that the best bit for doing the grinding is one that from the front looks like a chineese throwing star, but its about a 1/4" long.....this thing takes that aluminum out like nothing
Old Mar 25, 2007 | 02:49 PM
  #50
FastNeon84's Avatar
FastNeon84
yes you do
man my bad i went there thursday and them things were gone....[:@]
