My bottom end budget build PIX ADDED!
Old Mar 19, 2007 | 09:16 AM
HabitatHxC's Avatar
HabitatHxC
Default My bottom end budget build PIX ADDED!
So im making my list and checking it twice! Tell me if there is anything else I need!
JE pistons(10.5:1)and ringsEagle rods= $718.00
Full gasket set =$50.36
Rod bearings set=$29.99
Main bearing set=$110.00
Timing belt=$34.99
Main studs=$149.99
Head bolts=$38.48
Total $1131.81 Before shipping =D So if anyone has any better deals help me out!
I had a question about the FULL gasket set for 50 bux? found here on ebay http://cgi.ebay.com/ebaymotors/1996-...99859809QQrdZ1
They have 100% feedback so mabye its a good deal?
Old Mar 19, 2007 | 11:29 AM
das2123's Avatar
das2123
Default RE: My bottom end budget build
What about a new water pump and pulley? Why not 12.5:1 JE pistons?
Gasket set, looks good but I wonder what brand the HG is.
Old Mar 19, 2007 | 03:31 PM
spudsterier's Avatar
spudsterier
buy the bottom end kit from modern performance...
that way you have everything
Old Mar 19, 2007 | 05:14 PM
das2123's Avatar
das2123
That kit looks so tempting!!!!!
Old Mar 19, 2007 | 07:28 PM
spudsterier
if i would of had all the money in 1 shot then i would of got it instead....
but by piecing it together i got evem more then what the kit came with and still cost me less then it would of if i had gotten the kit from them
Old Mar 19, 2007 | 08:46 PM
rtneon67's Avatar
rtneon67
what all extra did u get cause im looking into getting the kit.. i figured it would cost the same or more if i would peace it together
Old Mar 19, 2007 | 08:57 PM
HabitatHxC's Avatar
HabitatHxC
ORIGINAL: das2123
If you can find a piston/rod/ring combo for that cheap help me out!! the only ones ive found are 10.5:1 Also would i be able to run on 93 octane?
Also I have a water pump, i did look at tensioners after i posted there not to expencive!
SPUD what are you doing about bolts? Are you keeping old bolts or using ALL new ones? I will be replacing head bolts i know, but what about the others?
Thanks for the good imput guys keep it commin!
Old Mar 19, 2007 | 11:30 PM
das2123's Avatar
das2123
ARP head bolts are top quality.
Old Mar 20, 2007 | 12:17 AM
spudsterier
thats what im getting....all ARP bolts....they are alot stronger and wont streatch as bad......if you plan on doing a real nice build then never use the old bolts....always use new ones....especially when the old ones are stock
8.8:1 JE pistons, eagle rods, JE rings cost me about $750.00
then i got complete prothane suspension bushings, prothane motor mount inserts, mpx oil pump, booger bushings, and crane valve springs.....that was another $375.00
crane #14 cams cost me $250
then the motor work is costing me about $700-$900
then there is TONS more[&:]
Old Mar 20, 2007 | 04:01 AM
unclemike's Avatar
unclemike
What about rebalancing?Are the Eagle rods close to stock weight?
