Car dies when cold
Old Mar 19, 2007 | 04:40 PM
art02gt's Avatar
art02gt
Default Car dies when cold
My car for some reason kept dying if I didn't keep it accelerated. So far I have replaced the fuel filter, spark plugs andPCV valve. Now it will only dieat the first start of the day, but after it dies if I start it back up it will be fine for the rest of the day. WTF?
Old Mar 19, 2007 | 05:14 PM
das2123's Avatar
das2123
Default RE: Car dies when cold
What about the fuel pump? Could be going out on you.
No CEL?
Old Mar 19, 2007 | 05:34 PM
art02gt's Avatar
art02gt
ORIGINAL: das2123
No CEL?
Yes i have a CEL for high input on o2 sensors and sometimes a code for the intake air temp. sensor. Is there anyway to test the fuel pump?
Old Mar 19, 2007 | 05:42 PM
das2123's Avatar
das2123
You can check the fuel pressure at the rail...49 psi.
Old Mar 19, 2007 | 05:46 PM
art02gt's Avatar
art02gt
ORIGINAL: das2123
I've checked it, it's at 49 psi.
Old Mar 19, 2007 | 05:59 PM
das2123's Avatar
das2123
Needs to be at 49 psi.
Check for restricted fuel pump inlet strainer, if thats good, then your fuel pump may be going bad on you.
Also check the fuel rail for debris.
Old Mar 20, 2007 | 12:16 AM
art02gt's Avatar
art02gt
ORIGINAL: das2123
It is at 49 psi. Debris on the outside of the rail or where exactly? I was thinking of getting some fuel injector cleaner, fuel pressure is normal so I don't think it might be fuel related.
Old Mar 20, 2007 | 12:19 AM
das2123's Avatar
das2123
My bad, I thought you said 40 psi[8D]
Have you checked your plugs, wires and/or coil pack? Grounds?
Old Mar 20, 2007 | 12:51 AM
art02gt's Avatar
art02gt
ORIGINAL: das2123
Just replaced the plugs, wires seem fine, grounds? and sorry I did put 40 psi at first instead of 49, i wasn't fast enough to correct it
Old Mar 20, 2007 | 12:57 AM
das2123's Avatar
das2123
I'm curious if its a loose connection/wire somewhere.
