radiator fan wire colors?
Old Mar 21, 2007 | 08:41 PM
97neon2dr's Avatar
97neon2dr
Default radiator fan wire colors?
i have a 97 neon 2 door. the idiot that put the motor off a 96 in itcut the wires going to the radiator fan. so i looked in the haynes for the wire that goes to the relay, colors didnt match up... it said dark blue/pink at pcm, which is on the driver side wheel-well right? then it said light green at power distribution center. right next to pcm right? anyone know the wire colors? i just wanna make sure i do this right. dont need to jimmy-rig the wiring like a hack ya know?
Old Mar 22, 2007 | 03:07 AM
neisg1's Avatar
neisg1
Default RE: radiator fan wire colors?
The Haynes diagram is correct for 95 & 96 Neons, in 97 the cooling fan relay was changed to a solid-state relay and relocated up front near the battery. Sorry but I don't have a wiring diagram for it.
