timing belt?
Old 03-28-2007, 11:19 AM
das2123's Avatar
das2123
das2123 is offline
Default RE: timing belt?
ORIGINAL: moretodo
The only thing that I can say is that my water pump just went out, I did not want too replace it my self so I called the dealer for fun, labor only was 298.00, the pump was 65.00 and the belt was 56.00 I told them thanks but no thanks so I'm going to rebuild one that I have sitting on the floor, have all the parts too do it anyway.
Did it snap the timing belt also? If so, you would want to change the belt and idler pulley at the same time while you are in there.
Quick Reply: timing belt?
