whats going on?
Old Mar 28, 2007 | 02:52 AM
iwalton63's Avatar
iwalton63
Default whats going on?
Ok so today my car was running and driving fine. I went to work just like everother day, but when I went to leave work, my car wouldnt turn over. It would attempt to start just not turn over. It took me a couple trys but I finally got it to start, once started the CEL was on.,and it had not been earlier. I check the codes and got 12,54,32....Ok I already knew about the EGR being bad, but I have not disconnected the battery in a while. As for the cam sensor, I just replaced that about 3 months ago.... so what is going on her?
Old Mar 28, 2007 | 06:52 PM
iwalton63's Avatar
iwalton63
Default RE: whats going on?
...anybody have an idea?
Old Mar 28, 2007 | 07:37 PM
spudsterier's Avatar
spudsterier
sounds like the car is mad at you...
Old Mar 28, 2007 | 07:55 PM
rrwertz's Avatar
rrwertz
check the battery terminals. maybe it's corroded. buy an egr block off kit or replace it.
Old Mar 28, 2007 | 07:56 PM
rrwertz's Avatar
rrwertz
run some seafoam or mopar combustion cleaner through it.
Old Mar 28, 2007 | 08:15 PM
das2123's Avatar
das2123
Check your connections to the cam sensor.
