Just stuck it back in. Not really a big problem right now. I want to get the paint done, interior sort of cleaned out, and the engine super-reliable before I do any stereo work.
I think my dad was kind of hinting at putting some driving lights on the front for some reason....can I run 2 55 watters without a big problem?
It worked earlier, now it's dead. I think the gauge itself is dead as I can turn the headlights on, highbeams, and the oil and gas gauges used to freak out, the gas doesn't do anything now.
sounds like you might possibly have some bad connections somewhere. most gas gauge problems are usually bad wiring or bad connections. if the wires on top of the tank are easy to get to you could test and see if you are getting the 5v that you should be at the sending unit. otherwise you may have to take instrument cluster out to test things
Alright, I guess I'll tackle that next week when I get the multimeter after work. Any ideas on how to get the cluster out? It needs some work. lol
I can get to it, but can't get it out because of the speedo cable.
