1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
My Perpetual 76 Project Thread
Old Apr 10, 2013 | 10:47 AM
  #151
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I guess I'll have to try that maybe next week.
Damn term paper.
Old Apr 15, 2013 | 04:34 PM
  #152
dodge dude94
Well, I am currently replacing the power steering fluid with ATF4 since the pump whines a bit.
Well, the steering had kind of been chunky for a little bit recently, but it has gotten way worse now. It's so bad I can barely turn the wheel and the pump is hanging bad. Does it just need to be bled and the level topped off? Help here...
Old Apr 15, 2013 | 05:29 PM
  #153
crazzywolfie's Avatar
crazzywolfie
does your power steering leak? if so just topping it up will probably be fine. if you don't have a leak you may want to jack the front end up and turn the steering wheel back and forth with the truck off. it will force the fluid out of the system and into the reservoir where you can siphon it out and replace it with atf. once you replace it you can fire the truck up and turn the steering wheel back and forth from lock to lock and it should refill the system with atf.
Old Apr 15, 2013 | 05:39 PM
  #154
dodge dude94
Well, I forced it to steer with the engine running.
It bled out enough to make it driveable. Funny thing is, it only does it while the truck is stopped, when moving it steers normally (6 in of slop, lol). I dunno what's up....
Old Apr 15, 2013 | 06:06 PM
  #155
crazzywolfie
is there any slack in the power steering belt? trucks with no power steering steer great when you are rolling but are a pain to steer when you are stopped.
Old Apr 15, 2013 | 08:02 PM
  #156
dodge dude94
Not much at all, since I had just tightened everything when I did the alt. belt. I think it's bubbles. They'll work out, right?
Old Apr 15, 2013 | 08:10 PM
  #157
crazzywolfie
hard to say. with how old the truck is it might be a worn out pump.
Old Apr 15, 2013 | 08:48 PM
  #158
dodge dude94
That's possible. But I'm gonna ride it out and see what happens.
I also torqued down the carb mounting bolts today too.
Vacuum leak comes and goes.
Old Jun 7, 2013 | 01:29 PM
  #159
dodge dude94
Gas gauge works every other time I start the truck and I'm really leaning toward the resistor thing in the gauge cluster. I was making sure everything was working today when I moved it and while testing the blinkers, I noticed the gas gauge and oil pressure going up ever so slowly. That's the resistor doing that, right?
Old Jun 7, 2013 | 01:31 PM
  #160
crazzywolfie
sounds like your voltage regulator on the back of the gauges might have a bad connection.
