1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
My Perpetual 76 Project Thread
Old Sep 19, 2013 | 12:00 AM
  #211
crazzywolfie's Avatar
crazzywolfie
i would have just put the tires on the truck and taken it to the carwash to rinse them off.
Old Sep 19, 2013 | 12:25 AM
  #212
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
It would have taken more effort, time, and money to do it that way than the way I did it.
Clean was a dollar, and I didn't use that much water.
Old Sep 25, 2013 | 05:38 PM
  #213
dodge dude94
Before:
Side shot after:
Old Sep 25, 2013 | 06:42 PM
  #214
crazzywolfie
they look good but they look a bit smaller than what use to be on there.
Old Sep 25, 2013 | 07:57 PM
  #215
dodge dude94
Yeah, they do, especially on the back. But let me tell you, they ride SOOO much better. Front and rear. Most of the annoying clunking is gone from the front end too, gonna be even better when I get the shocks installed. Which by the way, my rears have already come in. So I'm waiting on the fronts and provided they get here this week, they will be put on Monday.
I'm also starting to re-think that I want to do with the exhaust. My little patch failed and I'm noticing that it sounds a lot throatier than it did before even more I had the patch on it. I'm almost thinking about hacking both pipes off at the axle. Sure beats $100 to have duals put on it.
Old Sep 25, 2013 | 08:26 PM
  #216
crazzywolfie
do you have a caliper for measuring? if so you should measure what size the pipe is on both sides of the break. you might be able to cut the old connection out and install a new pipe that is a tiny bit larger and some exhaust clamps and you should be able to fix the old exhaust.
Old Sep 25, 2013 | 08:44 PM
  #217
dodge dude94
I'm not really going to worry about it much. I'm either going to have the duals re-done to behind the bumper, or I'm just going to hack it off at the axle. I just don't know which. The exhaust is really crappy where it splits off as the pipes are very old, back from when there was no such thing as mandrel bent tubing. It was bent, spread and welded together in pieces.
Old Sep 25, 2013 | 10:04 PM
  #218
dodge dude94
Oh yeah, new rear shocks came in today:
Beefy. Way bigger than the little pansy shocks on it now. For reference, my hand is 7 inches from the base of my wrist to the tip of my middle finger:
Old Sep 25, 2013 | 10:14 PM
  #219
crazzywolfie
i know exactly how large those things are. i got a set on my 93 and i think the set on my 81 are the same. hard to tell with all the rust.
Old Sep 25, 2013 | 10:21 PM
  #220
dodge dude94
We've got some on my dad's 02 and they aren't as big as these. Or at least they don't seem to be.
As far as install, you just cut the ties and start installing, right? Considering the ties go through the mounting holes....
