1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
My Perpetual 76 Project Thread
Old Jan 15, 2013 | 10:09 AM
  #81
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I need to replace the alternator/a/c belt and I have to pull the others off before I can get to it.
Just start unbolting pulleys or something?
Old Jan 15, 2013 | 11:59 AM
  #82
crazzywolfie's Avatar
crazzywolfie
you should only need to loosen the one bolt and it should let the alternator rotate down and belts should loosen..
Old Jan 16, 2013 | 10:01 AM
  #83
dodge dude94
Yeah, that's just the alternator belt, I still have the power steering and the idler belts in the way.
Old Jan 16, 2013 | 12:20 PM
  #84
crazzywolfie
if the power steering pump uses a bracket like the picture i posted, loosening both bolts and it should allow the pump rotate easily.
Old Jan 17, 2013 | 10:52 AM
  #85
dodge dude94
I don't think it does, but I'll look anyhow.
If I can, I'll be poking around under the hood again today.
Old Jan 18, 2013 | 09:52 AM
  #86
dodge dude94
Didn't find any adjustment for the PS pump. Looks like I'm back to square one on this.
Old Jan 18, 2013 | 10:10 AM
  #87
crazzywolfie
i think you may need to look a bit harder. is there a slot or something in any of the brackets? on my 81 you have to loosen the 1 water pump bolt to pivot the power steering pump.
Old Jan 18, 2013 | 10:26 AM
  #88
dodge dude94
Looks nothing like that, I guess I'll try cleaning the PS pump bracket and see what I can see.
Even so, it still leaves me with the idler belt, why that's even there I have no idea.
Old Jan 31, 2013 | 10:06 AM
  #89
dodge dude94
Got the voltage gauge installed.
Mounted it in a hole previously there.
Temp. ground.
Annnnd that's why.
Key on...
Blower on...
Engine running, everything off...
Engine running, blower on
Engine running, blower on, headlights on
Engine running, blower on, highbeams on
Whaddya think?
Old Jan 31, 2013 | 01:47 PM
  #90
crazzywolfie
looks like your dash is busted up. lol. looks ok otherwise. so did you get the stereo working or did you just stick it back in so you didn't have an empty hole in the dash?
