1st Gen RAM general discussion/NON-tech This section is for general discussions about your 1st gen RAM. Non tech related RAM threads belong here.
1983 D250 trying to get running again.
Old 06-25-2024, 02:19 AM
83D250's Avatar
83D250
83D250 is offline
Default 1983 D250 trying to get running again.
Where do I begin.... I impulse bought an '83 D250 to restore. So I'm currently trying to find a coolant reservoir tank, does anyone know where I could find one?
Old 06-25-2024, 08:16 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,384 Likes on 3,124 Posts
Probably not going to find an original. Check Summit Racing, or Jegs, they have bottles you can retrofit to your truck.
Old 06-25-2024, 08:36 AM
Machomur's Avatar
Machomur
Machomur is offline
Also check with LMC Truck
Old 09-14-2024, 12:47 PM
69_XS29L's Avatar
69_XS29L
69_XS29L is offline
That's your windshield washer tank.
If that plastic is not too brittle, there are a ton of videos/tools/methods for simple plastic repair to get you by until you settle on a permanent fix.
Old 09-14-2024, 08:22 PM
ol' grouch's Avatar
ol' grouch
ol' grouch is offline
That's not your coolant tank, that's your windshield washer tank. Try some of the truck restoration sites.
Old 09-14-2024, 10:24 PM
Los_Control's Avatar
Los_Control
Los_Control is online now
I think restore is a word often over used ..... I prefer repaired.
Seriously if you were going to restore the truck, you would strip it down to a bare frame and start restoring from there putting everything back to original.
A coolant reservoir would not even be close to one of your first questions on the truck.
I have a old truck I have been "repairing" for a couple years now .... I'm slow.
I'm not doing a restoration, just going through it and repairing it .... that includes replacing missing paint.
When it comes to a radiator, it was close to $2K to restore original honeycomb radiator .... I had a used radiator that is a huge 3 core and does not leak.
Sure it is beat up but free and does the job.
Finish it all off and give it some paint ..... I have a working cooling system for less then $50.
Here is my coolant reservoir I might add when I'm ready.
My only point is to try to keep you from getting lost in the weeds with restoration ...... You need a coolant reservoir tank .... fine, go to the wrecking yard and pick out one that will be satisfactory and work. ..... keep your eyes open for a original, you may find it .... in the meantime just repair it and make it work. So you can drive the truck and enjoy it.
You get too concerned about exact original parts, you will get discouraged and never drive the truck.
Old 09-15-2024, 09:46 AM
Blue Rebel's Avatar
Blue Rebel
Blue Rebel is offline
Try LMC truck, they will even send you a free catalog just for your truck. Also Rock Auto has them as well.
Quick Reply: 1983 D250 trying to get running again.
