360 heads on a 318
Old Jun 2, 2007 | 01:32 AM
outlaws318's Avatar
outlaws318
Default 360 heads on a 318
i have a 91 d150 with a 318 and looking to changing the heads. how much of a differ. would the 360 heads be from the 318? and what it give me more power?
Old Jun 2, 2007 | 06:42 AM
Maelthra's Avatar
Maelthra
Default RE: 360 heads on a 318
They're the same engine (LA series), I don't believe the heads are different, just the stroke.
Old Jun 2, 2007 | 07:02 AM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: outlaws318
I could be wrong but I believe the combustion chambers are larger on the 360 heads and that would lower your compression ratio and you would lose power.
Old Jun 2, 2007 | 01:24 PM
horatio102's Avatar
horatio102
The Captain is correct. For the LA engines, there are several different heads. The 318's have smaller chambers and yeah, you'll be losing compression and power. I don't have time right now, but you should look into getting some Magnum heads since they flow a lot better. Or try to find LA 318 heads from the mid/late 80s, they've got swirl ports and other things to help .
Old Jun 3, 2007 | 03:06 PM
89Ramcharger's Avatar
89Ramcharger
i wanna find out how to get more power and hp outta my truck with out doing any thing major any ideas? its an '89 dodge ram 1500 318
Old Jun 3, 2007 | 06:18 PM
dnfd737's Avatar
dnfd737
look for the whole upper motor that has 308 casting heads. These are a improved flow high swirl head. magnum heads would be better but carburating it is a pain and I am not sure of the compatibility of the magnum injection system on your truck.
Old Jun 4, 2007 | 01:37 AM
horatio102's Avatar
horatio102
The magnum heads don't have fuel injector bosses, those are in the intake manifold. Swapping in some Magnum HD heads would allow for way more airflow, and they're relatively inexpensive. You'd have to re-drill the mounting holes to adapt the intake manifold to the heads, but there are people out there who can tell you more about that.
Old Jun 4, 2007 | 05:03 AM
Maui_808's Avatar
Maui_808
what about 318 heads on a 360?
Old Jun 4, 2007 | 06:36 AM
dnfd737's Avatar
dnfd737
you know as far as carburated heads go....if it is a factory 4bbl they are 360 heads. I would not redrill magnum heads for the factory intake edlebrock makes a intake for magnum heads but its for a carb. http://www.allpar.com/mopar/4bbl.htmlhas a couple of articles on modifing a 318 and head info. I started here when I upgraded my satellite motor.
Old Jun 4, 2007 | 06:28 PM
outlaws318's Avatar
outlaws318
that site is lot of help, thanks
