bangs into drive and reverse
Old Jun 5, 2007 | 12:15 PM
mike63078's Avatar
mike63078
Default bangs into drive and reverse
Hello all
I am new to the dodge world and just picked up a 1986 D150 with a 318 and auto trans. When put it into reverse and drive it shifts real hard,
is this normal? any help would be appriciated
let me know
thanks
MS
Old Jun 5, 2007 | 03:33 PM
Maelthra's Avatar
Maelthra
Default RE: bangs into drive and reverse
Check the U-joints, they're probably shot.
Old Jun 6, 2007 | 02:40 AM
master tech's Avatar
master tech
Site Moderator & Tech
Also ck your engine RPM it maybe too high,or you have too much backlash in the rear diff.
Old Jun 7, 2007 | 03:18 PM
kurts2's Avatar
kurts2
Yea, I think they call it the spider gear in the rear end. If it is worn, it will bang when placed in fwd reverse or both, depending how worn out it is.
Old Jun 8, 2007 | 05:12 PM
PushnFords's Avatar
PushnFords
Worn spider gears will make the truck act like it has a posi. Extra backlash between the ring and pinion will cause a clunk in extreme circumstances. With your driveshaft disconnected and both rear wheels on the ground you should have a 1/4 of play in the axle yoke at most. If you are at 1/2 turn or more your rear end probably won't last a lot longer. Also make sure your u-joints aren't loose. Any play at all and they are bad. And, as previously said, an idle that is too high can cause a clunk too.
Derek
Old Jun 8, 2007 | 06:36 PM
mike63078's Avatar
mike63078
i think i may have it fixed we will see
