leveling kit for 88 ram w100
Old Jul 8, 2007 | 12:21 PM
jshelto3's Avatar
jshelto3
Default leveling kit for 88 ram w100
My brother would like to fit a 33" tire on his truck but the front end needs to come up about 2'. I was wondering if he couldn't just use a block to bring it up a little. If this isn't a good idea, any other would be appreciated. Thank ahead.
Old Jul 8, 2007 | 01:51 PM
outlaws318's Avatar
outlaws318
Default RE: leveling kit for 88 ram w100
find the specs on the front coil springs and try to match them with a nothing coil spring or look at heavy duty coil spring. is 4 wheel drive or 2 wheel drive and does it have a soild front axle. if its soild you can use block with no problem just get longer u-bolts.
Old Jul 9, 2007 | 08:27 PM
jshelto3's Avatar
jshelto3
it is 4 wheel drive with the solid front axle. This is why I was hoping a small block would do the trick.
